Plex is using 30% CPU constantly - Clean plex Installation, no media
Server Version#: v1.14.1.5488-cc260c476
Player Version#: Not applicable
Issue:
The following program is using 30% CPU constantly.
"C:\Program Files (x86)\Plex\Plex Media Server\PlexScriptHost.exe" "C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-cc260c476\Framework.bundle\Contents\Resources\Versions\2\Python\bootstrap.py" "C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-cc260c476\System.bundle"
I had the same issue with my old plex installation so I did a clean reinstall of plex. At this moment my plex is empty, But the issue persists.
If you need logs, Kindly mention the log file name. I can see too many files at the log directory.
Thank you.Plex Media Server Logs_2019-02-21_23-19-11.zip (59.3 KB)
In a browser going to https//app.plex.tv/web Settings > Troubleshooting will present you with an option to download your logs and then you can upload here. This zips up all the log files which they need for troubleshooting.
I have attached logs.
Thank you.
Turn on DEBUG but not VERBOSE for logging. Save and restart Plex.
The only thing showing right now is that your are double nat’d, if you turned on remote access turn that off for now.
It is fresh plex installation. I don’t recall changing log to verbose. As it was very annoying I had disabled it from startup. at this moment there is no spike. I don’t know when the spike starts but it starts.
Anyway, have you checked Plex Media Server.2.log Plex Media Server.3.log? There are lots of error about ‘curl_easy_perform’, SSL etc
