I have a directory like
Media
+Studio A
- Packs
- Scenes
+Studio B
- Packs
- Scenes
+Studio C
- Packs
- Scenes
Plex can see Packs, but not Scenes. If I make Studio A its own library, Plex can see Packs and Scenes? Any thoughts?
Media
+Studio A
- Packs
- Scenes
+Studio B
- Packs
- Scenes
+Studio C
- Packs
- Scenes
Give all directories containing media 755 permissions.
Give all media files 644 permissions.
The issue never was permissions. If you look at OP - Packs showed but Scenes did not. Scenes and Packs both inherited their permissions from parent directory. So permissions never was a problem. The problem is how Plex sees folders. Below is my solution.
I solved it on my own. I just Added Studio A, Studio B, Studio C directories to the library individually rather than the parent folder by itself. This also allows me to use a Python script I wrote to assign studio based on directory.
Solved.
