Plex item's advanced settings syncs changes across libraries with the same show
Server Version#: 1.29.0.6244
I have a TV show in two separate libraries linking to two different sets of files. They are separated because they are from another region, so they have different numbering and naming. When I am editing the advanced settings for one, it will change the other one in the other library which causes the numbering to no longer line up.
0 comments
Don’t know how you get around that other than unmatching one of the shows and inputting all the show data manually
If they are both matched Plex will treat them as the same show
You will even get double results when you watch the show in your continue watching unless you unpin one of the libraries
Screenshot (408)
As you can see, my only solution was to customize one of the posters so I at least know which show to pick
Ahh, welp. There are a ton of episodes so manually renaming them is going to take forever. The only problem is going to be the broken naming/numbering on one of them.
Although, when selecting the matches, it shows different posters and names for each by default. I don’t know if that matters though.
