I installed Plex on my windows 10 machine a few days ago and it worked great. apart from some naming issues as apparently my media being organized into Genre folders is a pain for Plex. but after I added each folder separately it worked great for a few days.
however for the last couple days the server has been closing a few minutes after I open it. while it’s doing the media scan I believe. I looked in the logs but didn’t see anything other than a few lines that said the server was shutting down. but not why. - also when I reopen it. it’ll open but not connect on the PC/Phone/network/etc until I end task on every ‘Python’ process, MediaScanner Proccess, Media Server, and I thought there was another one, MediaUpdater maybe? i’m not sure. i’d have to check again. anyways. if I end task on all those. then when the media server starts up I can connect to the server for a few mins. until it closes again.
So I’d like to upload the logs for someone here to take a look at as was recommended on my other post. - but there are a lot of logs, which ones do you need me to upload? - Currently there are 61 Logs at 55 Megs total for all of them.
Any help would be appreciated. this seems to be much much better than Serviio that I Had been using. thanks,
-Dev
