Plex keeps popping up the controls over and over
We normally watch shows by streaming from plex media server to our Chromecast via the Plex android app. Somewhat recently (last couple months?) it has started consistently popping up the controls for apparently no reason while we are watching. We don’t watch on the web player that often, but it happens there as well. It just pops up the controls/poster/progress bar for a couple seconds and then it disappears again.
At its worst, it’s done this 10+ times in a row every 30 seconds.
Any idea what’s going on here?
We have the exact problem. It have happend before but only a few times per hour. Now it can pop up, like you say, every 30 seconds.
Exactly same thing here. Streaming Plex to Chromecast on OS X El Capitan (v 10.11.16). Trying to downgrade to an older version of Plex, hoping this bug was introduced recently. There seem to be no more older versions archive, so I found this: https://www.reddit.com/r/PleX/comments/4rf40b/where_can_i_download_old_versions_of_plex_media/
Update: downgrading didn’t solve the problem.
Hey guys I don’t know if you know that but if you use the server ip address to access plex, and cast from there, the problem isn’t there.
For example I’m accessing mine from 127.0.0.1:32400
If I were to access it via app.plex.tv or Android app then the problem appears
Hope it helps!
I think that solution isn’t applicable to casting from android?
I’ve got the same problem on Local PMS (recent update to 1.1.4.2757) on openmediavault NAS, android app, chromecast.
Hope it helps!
I suppose that’s possible but doesn’t really help since we’re casting to a chromecast.
The problem has actually intensified since I first posted this, making Plex completely unusable via the android app → chromecast. The controls popup is even more frequent, it does microstutters when the controls pop up which causes subtitles to go out of sync, and we get fairly frequent complete transcoder failure errors which crash plex.
We can now only watch via the web interface which seems to be fairly solid. It made it all the way through Terminator 2 with only a couple popups of the controls.
This happens for us as well. It started a week ago (or something like that) and is very irritating. Hoping for a fix soon!
edit: using a chromecast 2, issue occurs with two different android devices. Chromecast, plex server and plex app updated
+1
Same happening here. Hopefully someone finds a solution.
Rebooting CC helps for awhile but eventually the popups, microstutter and sub offsyncs come back.
Same here casting from browser not android app. Controls pop up usually at the end of the file. Looks like a version problem, hope will be fixed soon.
Same. Please fix fast.
I have the same issue. At least for now, and waiting for this to be fixed soon, I found that in 720p the status bar doesn’t pop up (or almost never) when casting to my Chromecast. It happens at direct stream in original quality or high framerates, at least for me. Downgrading plex server or android app don’t work, keeps popping up…
Sorry, I mean 720 kbps instead of 720p.
Same issue casting from iOS
Same issue casting from desktop to chromecast 2…
Appears to be subtitle related? With subs disabled, I don’t have the popups. Sample size:1
Same here, with subs disabled, no popups of timebar and movie cover. So, it is a problem. I want my subtitles all the time :slight_smile:
I thought something was wrong with my hardware when this happened to me. Glad to know I’m not alone. I’m experiencing all the issues mentioned above. However, the popups don’t occur for me until about 40 minutes into the movie. Hoping Plex can look into this because I need my subtitles.
Amazing that such a major bug can be released and can exist for an entire week without even an aknowledgement or a notification. How many more suffer without the ability to search through forums?
We are not beta testers, Plex is expensive software and has a large user base.
I experience the same problem.
Many friends and family connect to my server using various devices and operating systems. Everyone with a (first generation) Chromecast is experiencing the appearing controls and playback halts. Playstation, NVIDIA SHIELD and Web playback is unaffected.
The relevant log file output during these issues is a repeat of these three lines
Oct 16, 2016 09:48:38.272 [4900] ERROR - Throttle: timed out trying to read chunk 65
Oct 16, 2016 09:49:01.841 [0584] ERROR - [Chromecast] [Subtitles] Request failed. [undefined] Count: 1
Oct 16, 2016 09:49:19.039 [2368] ERROR - handle_stream_read error 10053 An established connection was aborted by the software in your host machine
