Plex keeps stop running
i am very new to this and a friend helped me setup up my nas and plex but for the last 3 weeks it keeps stop running at least once a day anyone got any ideas ?
synology DS918+
Server Version#:1.18.7.2457
Plex Media Server Logs_2020-04-09_17-17-35.zip (3.0 MB)
Player Version# 4.31.1
Something is making the network on your Synology change.
Given it happens every day,
  1. I suspect you have DHCP giving it an IP address (from your modem router).
  2. DHCP refresh will make the adapters shutdown and restart.
  3. Your logs are consistent with such activity . Look at eth0 (LAN 1)
The solution it to assign your NAS a fixed (static) IP address.
Apr 08, 2020 10:55:27.550 [0x7fc2fdcaa700] DEBUG - NetworkInterface: Notified of network changed (force=0)
Apr 08, 2020 10:55:27.552 [0x7fc2fdcaa700] DEBUG - Detected primary interface: 0.0.0.0
Apr 08, 2020 10:55:27.552 [0x7fc2fdcaa700] DEBUG - Network interfaces:
Apr 08, 2020 10:55:27.552 [0x7fc2fdcaa700] DEBUG -  * 1 lo (127.0.0.1) (loopback: 1)
Apr 08, 2020 10:55:27.552 [0x7fc2fdcaa700] DEBUG -  * 4 eth1 (169.254.22.221) (loopback: 0)
Apr 08, 2020 10:55:27.552 [0x7fc2fdcaa700] DEBUG -  * 5 docker0 (172.17.0.1) (loopback: 0)
Apr 08, 2020 10:55:27.552 [0x7fc2fdcaa700] DEBUG -  * 1 lo (::1) (loopback: 1)
Apr 08, 2020 10:55:27.552 [0x7fc2fdcaa700] DEBUG -  * 3 eth0 (fe80::211:32ff:fec1:330d%eth0) (loopback: 0)
Apr 08, 2020 10:55:27.552 [0x7fc2fdcaa700] DEBUG -  * 5 docker0 (fe80::42:64ff:fed5:5eec%docker0) (loopback: 0)
Apr 08, 2020 10:55:27.552 [0x7fc2fdcaa700] DEBUG -  * 7 dockerb27069d (fe80::2489:8fff:fec3:47d4%dockerb27069d) (loopback: 0)
Apr 08, 2020 10:55:27.552 [0x7fc2fdcaa700] DEBUG -  * 9 dockera557235 (fe80::b882:c7ff:fef4:131a%dockera557235) (loopback: 0)
Apr 08, 2020 10:55:27.552 [0x7fc2fdcaa700] DEBUG -  * 11 docker1bbad62 (fe80::a0fe:6fff:feb4:21f3%docker1bbad62) (loopback: 0)
Apr 08, 2020 10:55:27.552 [0x7fc2fdcaa700] DEBUG - NetworkService: Got notification of changed network (first change: 0)
Apr 08, 2020 10:55:27.552 [0x7fc2fdcaa700] DEBUG - NetworkService: Dispatch network change after two second delay.
Apr 08, 2020 10:55:27.553 [0x7fc2fdcaa700] ERROR - getaddrinfo(172-17-0-1.abcdefghijklmnopqrstuvwxyz012345.plex.direct) failed: -3
Apr 08, 2020 10:55:27.553 [0x7fc2fdcaa700] DEBUG - Network: 172-17-0-1.abcdefghijklmnopqrstuvwxyz012345.plex.direct failed to resolve to 172.17.0.1 but instead yielded ""
Apr 08, 2020 10:55:27.553 [0x7fc2fdcaa700] DEBUG - PublicAddressManager: Obtaining public address and mapping port.
Apr 08, 2020 10:55:27.553 [0x7fc27fd11700] DEBUG - PublicAddressManager: Obtaining public IP.
Apr 08, 2020 10:55:27.553 [0x7fc27fd11700] DEBUG - HTTP requesting GET http://plex.tv/pms/:/ip
Apr 08, 2020 10:55:27.556 [0x7fc2fdcaa700] DEBUG - NetworkInterface: received Netlink message len=88, type=RTM_DELADDR, flags=0x0
Apr 08, 2020 10:55:27.556 [0x7fc2fdcaa700] DEBUG - NetworkInterface: Netlink address message family=2, index=3, flags=0x80
Apr 08, 2020 10:55:27.556 [0x7fc2fdcaa700] DEBUG - Network change.
Apr 08, 2020 10:55:27.556 [0x7fc2fdcaa700] DEBUG - NetworkInterface: Notified of network changed (force=0)
Apr 08, 2020 10:55:27.556 [0x7fc2fdcaa700] DEBUG - Detected primary interface: 0.0.0.0
Apr 08, 2020 10:55:27.557 [0x7fc2fdcaa700] DEBUG - Network interfaces:
Apr 08, 2020 10:55:27.557 [0x7fc2fdcaa700] DEBUG -  * 1 lo (127.0.0.1) (loopback: 1)
Apr 08, 2020 10:55:27.557 [0x7fc2fdcaa700] DEBUG -  * 3 eth0 (192.168.100.100) (loopback: 0)
Apr 08, 2020 10:55:27.557 [0x7fc2fdcaa700] DEBUG -  * 4 eth1 (169.254.22.221) (loopback: 0)
Apr 08, 2020 10:55:27.557 [0x7fc2fdcaa700] DEBUG -  * 5 docker0 (172.17.0.1) (loopback: 0)
Apr 08, 2020 10:55:27.557 [0x7fc2fdcaa700] DEBUG -  * 1 lo (::1) (loopback: 1)
Apr 08, 2020 10:55:27.557 [0x7fc2fdcaa700] DEBUG -  * 3 eth0 (fe80::211:32ff:fec1:330d%eth0) (loopback: 0)
Apr 08, 2020 10:55:27.557 [0x7fc2fdcaa700] DEBUG -  * 5 docker0 (fe80::42:64ff:fed5:5eec%docker0) (loopback: 0)
Apr 08, 2020 10:55:27.557 [0x7fc2fdcaa700] DEBUG -  * 7 dockerb27069d (fe80::2489:8fff:fec3:47d4%dockerb27069d) (loopback: 0)
Apr 08, 2020 10:55:27.557 [0x7fc2fdcaa700] DEBUG -  * 9 dockera557235 (fe80::b882:c7ff:fef4:131a%dockera557235) (loopback: 0)
Apr 08, 2020 10:55:27.557 [0x7fc2fdcaa700] DEBUG -  * 11 docker1bbad62 (fe80::a0fe:6fff:feb4:21f3%docker1bbad62) (loopback: 0)
Apr 08, 2020 10:55:27.557 [0x7fc2fdcaa700] DEBUG - NetworkService: Got notification of changed network (first change: 0)
Apr 08, 2020 10:55:27.557 [0x7fc2fdcaa700] DEBUG - NetworkService: Dispatch network change after two second delay.
ok i have changed it and will keep a eye on it thanks
