@MrTDI said:
Could this please fixed?
Its annoying that I cannot play any 1080p films with the plex pass server.
Unless you are willing to roll back your server version then PfK is totally busted.
After 1 minor fix and a handful of dev posts in almost a year then the chances of it being fixed this year are…well you can make your own assumption.
Mine just started working randomly. I am not sure if my friend changed his server version or if the kodi plex addon updated, but it is now working perfectly…
Interesting. Maybe the required fix was server side. It certainly isn’t anything to do PlexForKodi updating because that never happens.
I just setup plex for kodi on a relatives Firestick, because the Android App hasnt been working since the latest update. I have no issues with the same setup on my local Firesticks. The only difference with this setup is that its remote. I was getting this error on some files I tried to play. I managed to fix it by changing my “Server upload speed” from 15Mbps to 20Mbps. Which is odd because the file that wouldnt play is only 6Mbps.
Had another file fail even with the 20Mbps setting, that file was 7.2Mbps. I changed my server upload to 0 to disable the setting, now the file plays OK. Seems like Plex4Kodi isn’t obeying that setting correctly
Thanks @HitsVille, for pointing to this in the testing version thread, because this had totally fallen between the cracks. Apparently I failed to log an issue about, so as I have been going through the list of things to fix, this never came up.
In any case, I apologize to those who have been having issues and made to feel like this was being ignored. It was not intentional.
Unfortunately, I no longer have any logs related to this, so I need server logs that show this issue so I can see exactly what the problem is. If anyone wouldn’t mind sending me a DM with some logs, that would be greatly appreciated.
Thanks,
Rick
No worries Rick stuff happens. On long shifts at the moment but can reinstall over the weekend and grabs some logs if no-one beats me to it. The strangest thing is I have a remote server and a local server both hosting identical files.
Everything plays from the remote cloud server as far as i have noticed, however the vast majority of files throw the error when connecting to the local server. So clearly nothing to do with the files themselves. Also the files that do throw the error on the local server play fine in PMPv2 and via my shield so obviously not file corruption.or the likes.Very odd!
Really appreciate the response.
@bb12489 said:
Can we please get an update on this? I’ve had to rollback my server, just the same as everyone else to get my client working again.
I have submitted some logs to ruuk and noticed something in the server logs which I have also passed on to ruuk. It seems PfK doesn’t like Streaming Brain. I went into the server settings and removed the upload bandwidth limit and everything now plays fine. As soon as i put a limit in, playback fails again. @ruuk This explains why I don’t have issues with the remote box. Higher speeds so I never needed to cap the uploads.
Hopefully when ruuk has chance to take a look we should get a fix.
EDIT @HTPC-14 Sorry mate totally missed you already posted the same temporary solution.
No problems, I really just stumbled onto the fix. Looks like @ruuk has found the issue now too
Yeah he Pm’d me earlier saying it should be an easy enough fix.
Then i can put away the HTPC and Just use PfK on my Shield and not have to keep looking at the awful default Plex interface.
I believe I’ve fixed the issue. I was able to duplicate the behavior and discovered that the version comparison function was broken so that basically for some server versions it would decide the server didn’t have streaming brain so the app wouldn’t even check to see if it’s decision was OK with the server. I fixed that and the issue went away for me. I’ve attached a version with the fix. If anyone with the issue could test this version to verify it fixes the issue for them, that would be great.
Thanks,
Rick
Could you add this version to test repository? I can see v0.1.4a2 only in test repo.
Thanks,
Rick
I’ve just given this a test and it appears to be working well for me on a fresh install of openelec (kodi 17.3).
Nice to see that the app is supported again. Hopefully now at regular intervals. I have many users looking over an Android box and your app because the Android app is not usable at all.
Thanks for the update, runs without problems at all.
