Plex Library missing Recently Added
Server Version#: Version 1.24.3.5033
Player Version#:Latest (all clients)
I have two libraries (Anime, & TV Shows) with the “TV Show” Library type. I only want TV Shows to show up on the Home Screen, the library is set to “Include in home screen and global search”. And I see “Recently Released Episodes”, & “Recently Added in TV Shows” on the Home screen, the “Manage Recommendations” settings are set to show Recently Added in Recommended/Home/Shared Users libraries.
The second folder I don’t want to show on the home screen, and it’s set as “Exclude from home screen”, but when that folder is set to “Exclude from home screen” I lose the “Recently Added in Anime” in the Anime/Recommended Library. “ Manage Recommendations ” settings are set to show Recently Added in Recommended library, the option to "Merge Recently Added items" is unchecked
https://imgur.com/KpOYmi5
https://imgur.com/jkZ5Z2h
https://imgur.com/hvrY45t
If I enable “ Include in home screen and global search on the Anime Library Recently Added in Anime only shows on the home screen too, never on the Anime library Recommended page
This setup is what I run for two other libraries, both set to Library Type “Movie”, one is set to show on Home Screen (Movies) and works fine, the other (Movies - Anime) is set to “Exclude from home screen” but when you browse to the Recommended section of the Movies - Anime library you still have the “Recently Added in Movies - Anime” section
https://imgur.com/af3XSq8
All libraries mentioned in the post are also Pinned in Home screen
How do I get this category back in the recommended library?
thx for report we are looking into it.
Thanks, if you need logs etc let me know and I can pull them.
This is still happening, any update?
And this seems to no longer be true, once I set Include in home screen and global search on the Anime folder it now shows recently added on both the Home screen and the Anime library recommended screen.
I don’t see an update on report. I’ll poke folks about it but can’t make any promises about an ETA.
