Plex library update required
For a certain reason i have to use the tvdb agent for the series but plex does not let me, it requires me to update the library and when i do it goes back to the plex tv series scanner
What reason is that?
  • Is the show not listed on Plex‘s metadata?
  • Do you want/need an episode order only available on TheTVDb?
  • Is the show listed as something else on Plex‘s Metadata (e.g. a tv movie)?
There’s should be a way to deal with all that.
Plus… the legacy agents are due to be discontinued at some point.
I’m using a script to move my metadata and for it to work the tvdb ids have to match, so I need it to use that
Are you referring to the data available via Plex‘s APIs?
The dataset for episodes matched using the current-generation agent do list those…
<Guid id="imdb://tt0795829" />
<Guid id="tmdb://56479" />
<Guid id="tvdb://127265" />
