Trying to see if this is normal or not but when my server builds the EPG data or tries to refresh it, my CPU goes to 100% and stays pegged until it is finished. Is this normal and why does it take 5+ hours?
Specs.
HP Gen8
Xeon E3-1225
8GB DDR3 ECC
WHS 2011
1Gbps ETHO
50/50Mbps internet
The OS and Plex live on a 7200rpm drive on a Sata3 port.
I’ve just updated to PMS version 1.12.1.4885 on two different systems. One is a XPEnology build DSM 6.0 running on a Core i5 2500K and the other is a QNAP TS-451+ which uses a Quad Core Intel Celeron J1900 2.0 GHz (2.42GHz burst).
Generally speaking, I haven’t notice an issue with previous versions of Plex but I’ll keep an eye on this newly installed version. I see no high CPU usage as of yet but the guide update does seem slow.
Some time ago, some versions back I noticed after a PMS upgrade the CPU was pegged but that was on one out of three PMS. In that case I just uninstalled and fell back to the last known working version on that hardware.
