Hi all,
I recently set up a HDHomeRun Connect Quatro for live TV and DVR use. I’ve got the TV working fine, all the channels I want load with no issues. My problem is the recording. I can go into the guide on my server and select the shows I want to record, or even click record on a show currently playing and it doesn’t throw up any error. The problem is these shows are no where to be found, they don’t appear in my recorded shows… am I missing something here? They should be recording to my external hard drive connected to the server that stores all my movies. I’m able to pause live shows as well. I’m so confused, any ideas? Thanks!
Nothing huh? I guess I’ll re-setup the DVR and see if that fixes it, maybe something went wrong on initial setup. If not then I’ll probably just need to sign up for SlingTV or Hulu TV, the wife is getting upset that she can’t record her shows, lol
Happy to say that I got it all figured out. For whatever reason PLEX TV is unable to record onto my 4TB Western Digital Passport, once I changed the record location to the C drive everything recorded fine. I then came across the issue that NBC didn’t seem to want to show, kept getting an error. The error seemed to go away once I reset the HDHomeRun, but would return within a few hours. Finally updated the firmware on the HDHomeRun and NBC has been showing up no problem for about 16 hours now. Hoping that solved the issue.
