Plex Live TV DVR Schedule inconsistencies
Server Version#: 1.32.2.7002
Tuner Make/Model: Happuage HD DVB-T
Guide/Lineup name:
Using XMLTV?: No
Channel number/Name: BBC1 HD works ok, ITV1 HD does not.
I’m using Plex Live TV on Win10 server (1.32.2.7002) with feed from twin HD DVB-T feed which picks up UK Freeview and loads the Over The Air EPG. I have refreshed all channels and rebuilt guide.
I’m trying to record two series. EastEnders is a soap drama which is transmitted several times a week. For this I specify “All Airings” and I see that the schedule loads all available airings correctly. When I do the same for Coronation Street which is also a soap drama which is transmitted several times a week this fails with the message “No upcoming airings”. However if I select “This Eposiode Only” this works.
I have other DVR apps which use the same OTA EPG and can create a series of recordings for All Airings.
What can possible be going wrong as this is a very simple setup? Any advice is gratefully appreciated.
Paul
