Hi there
I’ve just setup my new HDHomeRun Connect and all seemed to be working well with Plex DVR.
However, I tried to create a recording schedule for Coronation Street and whilst it creates OK, it always displays “No upcoming airings”
Has anybody found this with Corrie or any other show?
Thank you,
M
I may have a solution for this already.
If I set the recording schedule to record all episodes, don’t specify HD but do restrict recordings to ITV HD 103, all is fine.
A little clunky, but hopefully it’ll solve the problem.
M
The UK soaps have caused issues with Plex for years, mainly due to them being date based instead of Season/Episode
As you have found, the ITV soaps do not get flagged as new episodes, so you need to set the option for recording new and repeat episodes (restricing to just itv is good, otherwise you get the old repeats on itv3)
How have the recordings worked for you?, I find them annoying as it groups both the days episodes as one (so last nights 7:30 & 8:30 one will be grouped together as one episode
I haven’t noticed the grouping thing and in fact, everything is recording faultlessly so far.
That said, I’ve set the DVR settings to transcode. The file size is much larger but the recordings were skipping a few frames now-and-then otherwise.
Good to here it is worked correctly, I have been watching live recently so cancelled the schedule recordings, must try it again
For me it had issues with the double episodes
ie, Wednesdays episodes would both be labelled as S59E226, instead of S59E225 & S59E226
