Server Version#: 1.41.3.9314 (Windows 10)
Player Version#: 4.141.0
Tuner Make/Model: HDHomeRun HDHR4-2US (Firmware: 20230713)
Guide/Lineup name:
Using XMLTV?:
Channel number/Name: ALL
My issue is the same issue that others have posted about. Plex Live TV does not release tuners when changing the channel.
Steps to reproduce the issue:
- Tune to a channel
- Tune to a second channel
- Tune to a third channel, receive error:
Playback Error
Could not tune channel. Please check your tuner or antenna.
HDHome Run Tuner log:
20241223-20:45:33 Tuner: tuner0 tuning 2.1 WCBS-HD (8vsb:605MHz-1)
20241223-20:45:34 Tuner: tuner0 streaming http to 192.168.3.102:64964
20241223-20:48:48 Tuner: tuner1 tuning 4.1 WNBC (8vsb:599MHz-1)
20241223-20:48:48 Tuner: tuner1 streaming http to 192.168.3.102:49480
20241223-20:49:14 HTTP: rejecting request from 192.168.3.102 - all tuners in use
Here is what the tuner log looks like when changing channels using emby:
20241223-11:30:57 Tuner: tuner0 tuning 2.1 WCBS-HD (8vsb:605MHz-1)
20241223-11:30:57 Tuner: tuner0 streaming http to 192.168.3.102:52883
20241223-11:41:28 Tuner: tuner0 http stream ended (remote closed)
20241223-13:00:02 Tuner: tuner0 tuning 21.2 CREATE (8vsb:605MHz-6)
20241223-13:00:02 Tuner: tuner0 streaming http to 192.168.3.102:53267
20241223-13:45:33 Tuner: tuner0 http stream ended (remote closed)
Clearly, Plex is not releasing the tuner when changing channels. In one of the related threads below, a Plex representative said this behavior is by design. However, this design makes it impossible to freely change channels. Is there a way to disable this behavior?
Related topics:
plex-debug.log (108.4 KB)
