Since some days, Plex on my Shield is showing collections within my movies folders, although nothing was changed.
Was there any update recently that could have caused this?
Or how can I get rid of the collections showing up?
Yes, it’s a new feature. Edit library>Advanced, then select how & if you
want it to show
I have latest server running, Version 1.11.1.4753, but in the Settings - Library - Advanced Options setting I cannot see anything about collections?
That’s odd. This is what I see on 1.11.1.4730
Sorry, I was looking on the plex web interface. Did you mean on the Shield itself?
Don’t have that next to me now.
Sorry, forgot image.
Ok thanks, now I see, I was searching in the library settings inside the global setting, not the libraries settings.
Now I will have to do it for every single library I have, and that’s many, around 50. I have time
Thanks a lot.
Might just use the option “hide items which are in collections” though, as at the moment it shows me both next to each other, the individual movie, plus the collection, which is absolutely not nice.
Wrong place don’t see a delete button
