Plex Marks Media as Unavailable After Library Scans
Hi Plex Community,
I’m running into an odd issue with my Plex setup and hoping someone can help. Here’s the situation:
####Setup Details
  • Plex Server: Running on an intel Mac Mini, macOS Sequoia (13.x).
  • Media Storage: Synology NAS, shared via SMB. The share is mounted on the Mac as /Volumes/media.
  • Library Path: /Volumes/media/movies is added to the Movies library.
  • Access: The NAS share is mounted using an account with read/write permissions on the NAS. Files are accessible via Finder and even in Plex (even when marked unavailable).
  • Server Version#: 1.41.3.9314
    Player Version#: 1.41.3.9314 (plex web)
The Issue
  • Everything had been working fine (for years) until this past week, when about half of the movies suddenly were marked “unavailable”.
  • If I remove and re-add the media folder in the “edit library” dialog, Plex initially scans the files correctly, and all titles are available.
  • On subsequent library scans, Plex marks about half of the movies (1,045 out of 1,980) as unavailable. These same files:
    • Still play fine if selected directly in Plex.
    • Remain accessible through Finder and the mounted volume.
  • Re-adding the library temporarily fixes the issue, but it repeats after scanning again.
Troubleshooting Done So Far
  1. Permissions:
  • Verified that the account used to mount the share has full access to the NAS share and files.
  • The Plex process can read /Volumes/media since files play manually.
  1. Plex Database:
  • Backed up and rebuilt the library by deleting and re-adding it.
  • Forced metadata refresh and cleared old cached metadata for the library.
What I Think Might Be Happening
It feels like Plex might be:
  • Misinterpreting unchanged folders/files as removed during scans.
  • Failing to retain the correct paths or metadata in its database.
Has anyone else experienced media being incorrectly marked as unavailable on a macOS server setup? Any suggestions on how to debug further or resolve the issue?
Thanks in advance for your help! Happy to provide logs or more details if needed.
Known issue:
Good Luck,
Chris
Wow! thanks for pointing me to the thread - I had not found it on my own. Appreciate the direction. sounds like smart folks are working on this, i’m reading up on the workarounds. thank you.
