Plex media guide is missing channels
When viewing the plex channel guide I’m not seeing all availible channels.
The list appears to be static, meaning when I view the availible channels in HDHOMERUn I’m missing roughly 30 channels in the Flex guide.
I’ve restarted the server and HDHOME run appliance.
Is there any known issues for resolving this issue .
The server is running on NVIDIASHield TV and running the latest version.
If this is for OTA, you can try nearby postal codes to see if you get a channel lineup that reflects your reception better.
Darcilicious thanks for your reply, I’m not sure I follow your suggestion.
My understanding is the channel lineup is provided by my OTA device HDHOMERUN.
Nope, Plex provides it the EPG based on what it thinks your lineup should be based on your postal code.
FWIW, this has worked for other folks, especially if you’re physically situated such that your antenna gets more channels than is expected for your postal code.
Do you know how to update the postal code after the DVR is setup? There is one affiliate that I get and the Tuner Gets in, but I cannot pull the EPG for it to map it to the channel. Was hoping to use a different zip code to map it. Dont see a way to do this but do not want to setup my DVR again since i have several recordings already scheduled.
Yeah, I don’t think it can be done without deleting and re-adding the DVR :frowning:
