Plex Media Player is not compatible with Big Sur
I did a completely clean install of macOS Big Sur yesterday and went to install Plex Media Player today and I get:
“Plex Media Player” can’t be opened because Apple cannot check it for malicious software.
This software needs to be updated. Contact the developer for more information.
Now, I know I can override this but I would rather Plex fix this quick.
As a workaround, try pressing <option> after right-clicking on the app in the applications folder with Finder. This should give you the option to “open anyway” and only needs to be done once.
This is what I have done for now, but the developers need to address this still.
I think you should at least change the title of the thread. It’s not in line with the actual issue.
Same here, updated to Big Sur yesterday, now Plex won’t run.
Ver.
1.20.5.3600-47c0d9038
November 17, 2020
I gather your talking Plex media server and not player. If so you need start your own discussion.
On another note, I have PMS working perfectly on Big Sur. You may have a Extension or AV that is creating your issue
Same problem here. There must be some security change that is causing Plex to choke. In my case, no live TV.
Same problem here. I had initially installed Plex server on an older OS and then upgraded to Big Sur. No issue. I decided to rebuild my Mac mini and went straight to Big Sur and now I get these errors. Plex seems to be running ok though I think…
“libaac_decoder.dylib” can’t be opened because Apple cannot check it for malicious software.
“libhevc_decoder.dylib” can’t be opened because Apple cannot check it for malicious software.
“liblibmp3lame_encoder.dylib” can’t be opened because Apple cannot check it for malicious software.
“libmsmpeg4v3_decoder.dylib” can’t be opened because Apple cannot check it for malicious software.
“libdca_decoder.dylib” can’t be opened because Apple cannot check it for malicious software.
“libmp2_decoder.dylib” can’t be opened because Apple cannot check it for malicious software.
“libh264_decoder.dylib” can’t be opened because Apple cannot check it for malicious software.
“libwmv3_decoder.dylib” can’t be opened because Apple cannot check it for malicious software.
“libmp3_decoder.dylib” can’t be opened because Apple cannot check it for malicious software.
“libmpeg4_decoder.dylib” can’t be opened because Apple cannot check it for malicious software.
“libac3_encoder.dylib” can’t be opened because Apple cannot check it for malicious software.
“libac3_decoder.dylib” can’t be opened because Apple cannot check it for malicious software.
“liblibx264_encoder.dylib” can’t be opened because Apple cannot check it for malicious software.
“libwmav2_decoder.dylib” can’t be opened because Apple cannot check it for malicious software.
