Plex Media Scanner crashing every night
Server Version#: 1.18.3.2156
My Plex Media Scanner has started crashing every night for the last few weeks. I have been trying to figure out what’s causing it, but no luck. A manual update of each item in the library doesn’t seem to cause any crash.
I have included my logs if someone is able to assist me.
Thanks,
JimPlex Media Server Logs_2019-12-19_08-17-47.zip (5.9 MB)
Bump…
Same issue here. Seems to be since 1.8.x came out.
Do you guys have music in your library? If so remove it and that should stop the crashes.
So I can’t listen to music anymore?
I’m just telling you what worked for me LOL. If it worked I’m glad I could help you out. Hopefully eventually they’ll fix the bug.
