Server Version#: 1.14.1
I have every single option in Library Settings to Scan Auto/Partia/Peridically what not unchecked. I want to scan manually on my own time.
Yet, the scanner fires up and start scanning my media drive/folder!!!
Please advise.
Please advise.
Check your Scheduled Tasks under Settings
Also these setting may trigger a scan. (Settings -> Library)
And make sure you show advanced options.
here are my settings:
After a restart of the PC, the scanning hasn’t fired up though, Yet!
I’ll update if it does {or not]
Thanks for your reply mate.
Don’t forget to disable ‘Update all libraries during maintenance’ under
Settings - Server - Scheduled Tasks
