Server Version#: 1.19.1.2701
Player Version#:4.22.3
I see following error in windows event log:
Faulting application name: Plex Media Scanner.exe, version: 1.19.1.2701, time stamp: 0x5ea1b197
Faulting module name: ntdll.dll, version: 10.0.18362.815, time stamp: 0x2995af02
Exception code: 0xc0000374
Fault offset: 0x000dfa1d
Faulting process id: 0x2a78
Faulting application start time: 0x01d61e08581ed5d4
Faulting application path: C:\Program Files (x86)\Plex\Plex Media Server\Plex Media Scanner.exe
Faulting module path: C:\WINDOWS\SYSTEM32\ntdll.dll
Report Id: bb3aac8f-d7be-4fc9-860c-df09dc428fae
Faulting package full name:
Faulting package-relative application ID:
Windows is windows 10 version 1909 os build 18363.815
I believe I can make the problem happen on demand by running this command:
“C:\Program Files (x86)\Plex\Plex Media Server\Plex Media Scanner.exe” --analyze-loudness --force --item 166186 --log-file-suffix " Deep Analysis"
The files being analyzed are M4A. Any ideas? I am able to play the files in question just fine. I just like to clean up these crashes. It seems to happen on other deep analysis of music M4A files.
The deep analysis log ends with these messages:
Apr 29, 2020 05:27:04.739 [9568] WARN - [FFMPEG] - Sample rate index in program config element does not match the sample rate index configured by the container.
Apr 29, 2020 05:27:04.739 [9568] WARN - [FFMPEG] - Too large remapped id
Apr 29, 2020 05:27:04.739 [9568] WARN - [FFMPEG] - is not implemented. Update your FFmpeg version to the newest one from Git. If the problem still occurs, it means that your file has a feature which has not been implemented.
Apr 29, 2020 05:27:04.739 [9568] WARN - [FFMPEG] - If you want to help, upload a sample of this file to ftp://upload.ffmpeg.org/incoming/ and contact the ffmpeg-devel mailing list. (ffmpeg-devel@ffmpeg.org)
Apr 29, 2020 05:27:04.739 [9568] ERROR - Analysis: Codec error ‘Not yet implemented in FFmpeg, patches welcome’.
Apr 29, 2020 05:27:04.739 [9568] DEBUG - [FFMPEG] - stereo with SCE
Apr 29, 2020 05:27:04.739 [9568] ERROR - [FFMPEG] - Number of bands (45) exceeds limit (35).
Apr 29, 2020 05:27:04.739 [9568] ERROR - Analysis: Codec error ‘Invalid data found when processing input’.
Apr 29, 2020 05:27:04.739 [9568] ERROR - [FFMPEG] - Inconsistent channel configuration.
Apr 29, 2020 05:27:04.739 [9568] ERROR - [FFMPEG] - get_buffer() failed
Apr 29, 2020 05:27:04.739 [9568] ERROR - Analysis: Codec error ‘Invalid argument’.
Apr 29, 2020 05:27:04.739 [24008] WARN - [FFMPEG] - Sample rate index in program config element does not match the sample rate index configured by the container.
Apr 29, 2020 05:27:04.739 [24008] ERROR - [FFMPEG] - Inconsistent channel configuration.
Apr 29, 2020 05:27:04.739 [9568] ERROR - [FFMPEG] - Prediction is not allowed in AAC-LC.
Apr 29, 2020 05:27:04.739 [24008] ERROR - [FFMPEG] - get_buffer() failed
Apr 29, 2020 05:27:04.739 [24008] ERROR - Analysis: Codec error ‘Invalid argument’.
