Plex Media Server Manually stops in Diskstation
Just happens randomly, I can’t cause it to happen.
Next time it stops, please grab the logs again and post.
:crossed_fingers: the updated logs will contain just enough different info for me to see a commonality
Latest logs after stop.
Logs.zip (7.9 MB)
Plex Media Server Logs_2021-12-02_11-14-28.zip (7.6 MB)
I have the same issue, please find the log files attached.
Logs Plex.zip (2.4 MB)
The Plex Media Server icon disappears from the Synology menu, and when I go into the package centre to restart, it says “manually stopped”.
Same problem. DSM 7 running on DS1618+. Stops randomly with no apparent reason (sometimes works fine for a whole day, sometimes stops every hour), always with “Manually stopped” in the Package center and no apparent problems in logs. Any hints? I was on a verge of buying a lifetime but this is a show stopper for me.
Just updated the DSM and Plex to the latest version, the issue persists. I would really like to hear from Plex developers if they are going to fix (or at least admit) the issue.
“Sorry, there was an error uploading that file. Please try again.” — no matter how many times I try to upload the log file, this is what I get.
For all those dealing with the same problem: here’s an easy, step-by-step guide to install Plex Server in DSM7 as Docker: https://www.wundertech.net/use-docker-to-set-up-plex-on-a-synology-nas/
