I think I’m out of the woods Chuck. I checked perms on my media folder before the Nuclear Option and found that Plex did not have access. Added it & rolled the DS, and now it’s screaming along.
One difference on Synology from the other NAS vendors is PMS doesn’t run as if the Adminstrative user per Synology’s request. They want it constrained and well behaved which makes good sense.
Unfortunately that means you have to give user ‘plex’ access to what you want.
Fortunately, you can prevent PMS from deleting anything by accident even if you have deletion enabled.
interestingly, due to an issue I had (PMS not being able to scan my library), I deinstalled the previous version of PMS and downloaded the latest sinology PMS following the steps giving by you above, and now happily I have full access to the media folder.
But, suprisingly, I noticed that the shared plex folder originally created in the previous version of PMS was this time not recreated after the update of PMS. Is this correct or something weird here? Thx.
I’m having the same issues. I recently purchased a DS918+ and I installed the Plex app. I wasn’t given the option to set up my server. It just kept “looking for server” and spinning. I uninstalled the app and downloaded it from the Plex site and did a manual install to no avail. I checked permissions and the Plex user had read/write access. I have attached my logs. Logs.zip (90.7 KB)
@ChuckPa - I did not have this exact problem, but your post guided me to use the logs to find out what was happening, and it was awesome. After several days of bouncing around blind to solve an unresponsive plex server instance, the log pointed out that the constant churn while I loaded 185,000 songs into my NAS was driving plex nuts looking for metadata and scanning. I removed the music library and all is good now with the video side. I will wait until my music file is fully sync’d before turning that library on again. Thanks!
