Server Version#: 1.15.4.994
Player Version#: on LG 3.98.0, on Samsung 3.92.3, on Apple TV 2.1 (1)
NAS model# QNAP TVS 1282T3
NAS version# 4.3.6.0923
Switch model# Cisco SG250X-24 with 10gb/s gic port for QNAP server
TV model# LG Oled 65E6V
TV model#Samsung UE43LS003NA
Apple TV model# 4K 64gb
Network cables model# Cat. 6a
Movie model#
Codec HEVC
Débit 52701 kbps
Bit Depth 10
Chroma Subsampling 4:2:0
Color Primaries bt2020
Color Range tv
Color Space bt2020nc
Color Trc smpte2084
Frame Rate 23.976 fps
Height 2160
Niveau 5.1
Profile main 10
Ref Frames 1
Width 3840
Display Title 4K (HEVC Main 10 HDR)
Codec TRUEHD
Chaînes 8
Débit 3568 kbps
Langue Français
Audio Channel Layout 7.1
Bit Depth 24
Sampling Rate 48000 Hz
Titre TrueHD 7.1
Display Title Français (TRUEHD 7.1)
Codec DCA
Chaînes 6
Débit 2368 kbps
Langue Français
Audio Channel Layout 5.1(side)
Bit Depth 16
Profile ma
Titre DTS-HDMA 5.1
Display Title Français (DTS-HD MA 5.1)
Codec AC3
Chaînes 6
Débit 448 kbps
Langue Français
Titre AC3 5.1
Display Title Français (AC3 5.1)
Codec TRUEHD
Chaînes 8
Débit 3579 kbps
Langue English
Bit Depth 24
Titre TrueHD 7.1
Display Title English (TRUEHD 7.1)
Codec DCA
Chaînes 6
Débit 2363 kbps
Langue English
Bit Depth 16
Profile ma
Titre DTS-HDMA 5.1
Display Title English (DTS-HD MA 5.1)
Codec PGS
Langue Français
Header Compression true
Titre Forced
Display Title Français (PGS)
Codec PGS
Débit 19 kbps
Langue Français
Titre French
I’m plex pass user and activate “hardware transcoding”
My Plex Media Server directory (and all files and sub directory) are on CH7777 mod on my QNAP.
During my tests, my CPU was not use more than 20% event I selected make my CPU suffering in the transcoder setup. My ram was not used more than 10%.
When I play the same movie on different devices I have the following problems
On Samsung
With 7.1 truehd or DTS-HD MA 5.1 and with or without subtitles. I don’t have any errors message in the console. but is buffering for long period of time every few minutes and I can’t watch this movie.
Apple TV
When I select 7.1 truehd and no subtiles is buffering for long period of time every few minutes and I can’t watch this movie.
I have those error messages
May 19, 2019 18:04:28.000 [0x7f0cffd11700] Erreur — [Transcoder] [truehd_eae @ 0x357fe80] EAE timeout! EAE not running, or wrong folder? Could not read ‘/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Library/tmp/pms-736576cd-4af9-4f3c-ab7a-9269ea7eb04f/EasyAudioEncoder/Convert to WAV (to 8ch or less)/8F5CB866-9589-4FB6-AAD7-507F3C4325A6_27860-0-36.wav’
May 19, 2019 18:04:28.016 [0x7f0db520a700] Erreur — [Transcoder] [truehd_eae @ 0x357fe80] error reading output
May 19, 2019 18:04:28.016 [0x7f0ddc401700] Erreur — [Transcoder] Error while decoding stream #0:1: Input/output error
With 7.1 truehd or DTS-HD MA 5.1 and with subtitles. I don’t have any errors message in the console. but is buffering for long period of time every few minutes and I can’t watch this movie.
On LG
When I select 7.1 truehd and forced subtiles or no subtitles is buffering for long period of time every few minutes and I can’t watch this movie.
May 19, 2019 18:16:20.000 [0x7f0d7dfc5700] Erreur — [Transcoder] [truehd_eae @ 0x37fbe80] EAE timeout! EAE not running, or wrong folder? Could not read ‘/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Library/tmp/pms-736576cd-4af9-4f3c-ab7a-9269ea7eb04f/EasyAudioEncoder/Convert to WAV (to 8ch or less)/29hndh9pqdm42t9x9onj2kc6_6231-0-20.wav’
May 19, 2019 18:16:20.074 [0x7f0ccb735700] Erreur — [Transcoder] [truehd_eae @ 0x37fbe80] error reading output
May 19, 2019 18:16:20.074 [0x7f0d7dfc5700] Erreur — [Transcoder] Error while decoding stream #0:1: Input/output error
When I select DTS-HD MA 5.1 and forced subtitles is buffering for long period of time every few minutes and I can’t watch this movie.
I have this error message
May 19, 2019 12:33:11.682 [0x7f0d7f447700] Erreur — Unable to find client profile for device; platform=webOS, platformVersion=3.3.0, device=, model=OLED65E6V-Z
When I select DTS-HD MA 5.1 and no subtitles I can watch this movie. Even if I have this error message
May 19, 2019 18:20:38.546 [0x7f0d7ffff700] Erreur — Unable to find client profile for device; platform=webOS, platformVersion=3.3.0, device=, model=OLED65E6V-Z
Can somebody help to solve my issues, please ?
I really, would like to enjoy a 4K movie with all the material that I bought for.
Thanks.
