Plex Media Server
Plex Media Server 1.14.1.5487 is now available to Plex Pass users in the Beta update channel
NEW:
  • (Web) Updated to 3.77.4
FIXES:
  • (DLNA) DLNA clients would not report timeline states for Now Playing (#9347)
  • (DVR) Don’t return an error message when shutting down a live TV session in a normal way (#9277)
  • (DVR) Recordings could be missed when the ‘HD only’ setting was selected (#9226)
  • (DVR) Properly parse episode number from dd_progid field in XMLTV data (#9419)
  • (DVR) Wait longer to detect duration during live TV transcoder startup (#9437)
  • (HTTP) Enabling IPv6 support could prevent IPv4 connections from being accepted on some FreeBSD systems (#9405)
  • (Radio) Only expose Discovery Radio if there is a linked TIDAL account (#9428)
  • (Relay) The relay service may not function when server support for IPv6 is enabled on some systems (#9399)
  • (SSDP) Better checking for invalid IP addresses in location field of SSDP XML
  • (Streaming Brain) More exact accounting of bandwidth buckets to reduce bandwidth going unused (#9273)
  • (Subtitles) Some subtitles could not be downloaded by shared users (#9323)
  • (Subtitles) Subtitles aquired by the OpenSubtitle agent could cause playback failures on Nvidia SHIELD
  • Improve robustness when routers fail to respond to port-mapping refresh requests in time (#9107)
  • The server could crash when using network interface aliases on macOS (#9344; rdar://46083980)
Plex Media Server 1.14.1.5488 is now available to Plex Pass users in the Beta update channel
NEW:
  • (DVR) New DVR scheduler
FIXES:
  • (DVR) Fixed bug that prevented scheduling of recordings with HD only setting. (#9226)
  • (DVR) Revert timeout changes, should help with timeouts during tune startup (#9473,
Plex Media Server 1.14.1.5488 is now available to everyone.
  • This includes support for the new dashboard, available to Plex Pass users using the hosted web app (https://plex.tv/web)
Plex Media Server 1.15.0.647 is now available to Plex Pass users in the Beta update channel
This version contains numerous changes and a lot of invisible behind the curtains stuff. There a few caveats and some missing builds at this point:
Notes:
  • Thecus Builds for Thecus devices will not be available at this time. Thecus is working on a firmware update that allows the new PMS to run on their devices.
  • Docker If you are running our PMS docker container (or Linuxserver.io’s container) you will need to ensure the container is up-to-date before PMS 1.15.0 will run.
  • Nvidia SHIELD builds are slightly delayed and will be available on Google Play store once QA testing has completed.
  • RedHat/CentOS/Fedora Plex Media Server now only supports running on systemd-based versions of these distros. In addition, CentOS 6 is no longer supported due to an incompatible GLIBC version (PMS on Linux now requires GLIBC 2.14 or newer)
  • Ubuntu We now have official ARMv7 and ARMv8 deb packages.
  • QNAP Plex Media Server now only works on QTS 4.3 and newer. This means that we no longer offer Plex Media Server for QNAP devices with 32bit Intel processors.
See our “Changes for QNAP and CentOS support in Plex Media Server” post for additional details.
NEW:
  • (Linux) Support for Ubuntu/Debian ARMv7 and ARMv8 platforms.
  • (NAS) Support for ASUSTOR, Synology, and QNAP ARMv8 devices.
  • (NAS) Support for hardware encoding on QNAP Intel/AMD 64-bit devices with a discrete Nvidia GPU.
  • (NAS) Support for volume selection, and app migration on QNAP devices.
FIXES:
  • (DVR) Avoid a few crashes around parsing bad JSON from OnConnect (#8889)
  • (DVR) Avoid caching EPG HTTP cache requests for longer than the refresh time (#9629)
  • (DVR) Avoid downloading XMLTV files to disk before parsing (#9272)
  • (DVR) Certain scheduled recordings would incorrectly show an error. (#9325)
  • (DVR) Change the way Plex Tuner Service returns keys for TVButler devices, especially on macOS, to properly handle using multiple TVButlers on the same system. N.B. This is a breaking change for users of TVButler devices. Those users will need to delete and recreate their DVR to use the new device information. (#8760)
  • (DVR) Disk space checking underestimates the necessary amount of space when starting recordings (#8807)
  • (DVR) Ensure grab operations get destroyed after a tune fails (#9465)
  • (DVR) Fixed a bug where changing recording priority would not update the schedule. (#9035)
  • (DVR) Log which device we’re allocating a tuner from
  • (DVR) Output signal strength/quality information into log periodically during tunes (#9503)
  • (DVR) Plex Tuner Service now properly detects when a transcode session exited due to signal failure and releases the tuner (#9174)
  • (DVR) Translate Guide header for clients to display (#8698)
  • (Library) Library summary endpoint should report the correct duration for large music libraries (#9223)
  • (Live TV) Fix for intermittent tune failures. (#9412)
  • (Live) Avoid delaying video playback while leading audio plays (#9343)
  • (Music) Restricting music libraries with labels could prevent them from loading. (#8935)
  • (Scanner) Add support for reading Opus metadata (#5974)
  • (Transcoder) Seeking in DASH streams could be unreliable (#9137)
  • Corrected rare crash involving accessing User data (#9464)
  • Removed some remaining uses of plaintext HTTP (#8958)
  • The server could crash when TV media was being deleted. (#9350)
  • Updated translations
Plex Media Server 1.15.0.659 is now available to Plex Pass users in the Beta update channel
This version contains the following fixes in addition to the changes in 1.15.0.647:
  • Fixed an issue with hardware transcoding on Windows
  • Fixed an issue where comskip donor features were inactive
  • Fixed an issue with NetGear and RPM packages
  • Fixed an issue where Western Digital devices would offer an update to an old version (Requires a vendor-side change we are still working on)
See this post for links until the downloads page catches up: Much faster (hopefully), smaller (mostly) and better PMS builds preview (1.15.0.573-123756e9a)
Plex Media Server 1.15.1.707 is now available to Plex Pass users in the Beta update channel.
NEW:
  • (On Deck) Added preference for showing season premiers in On Deck
  • (Web) Updated to 3.83.1
FIXES:
  • (DVR) Better support for the dd_progid field in XMLTV. Adds handling of SH and MV tags. (#9680)
  • (DVR) Display a better error message when there is a duplicate channel mapping when configuring a DVR (#9606)
  • (DVR) Don’t let DVR content refreshes take place simultaneously.
  • (DVR) Fix for Live TV session not getting stopped when a recording needs the tuner
  • (DVR) Handle original-air-date field in XMLTV correctly if it doesn’t include a time (#9593)
  • (DVR) Recording files with non-ASCII characters in filename could fail on macOS.
  • (DVR) Scheduler would use large amounts of memory with many recordings scheduled. (#9050)
  • (Dashboard) Some playback sessions were not displayed (#9705)
  • (HTTP) Connections could become unresponsive after a long-poll response (#9713)
  • (Library) “Scan library automatically” did not work on MacOS (#9695)
  • (Library) Smart playlists with multiple tags (e.g. genre and genre) didn’t work correctly.
  • (Library) When rematching an item, preserve any uploaded media.
  • (Live TV) Fix for sessions not ending after tune failure. (#9465)
  • (Playlists) Playlist items would fail to load given certain parameters (#8963)
  • (Transcoder) Segments near the end of a session could be dropped (#9702)
  • Avoid crash at startup when scanning remote media servers (#9664)
  • Pull in episode ratings from TMDB.
Plex Media Server 1.15.1.710 is now available to Plex Pass users in the Beta update channel
This build has the following changes on top of the prior 1.15.1 releases.
FIXES:
  • Support for hardware transcoding on Windows has been restored
  • The Donator build of comskip is now included.
Plex Media Server 1.15.1.780 is now available to Plex Pass users in the Beta update channel
FIXES:
  • (HTTP) Server could become unavailable when using the Samsung app (#9784)
  • (Metadata) Lockouts when scanning / refreshing metadata (#9704)
  • (Windows) Crashes as a result of database contention (#9663)
Plex Media Server 1.15.1.791 is now available to Plex Pass users in the Beta update channel
FIXES:
  • (Transcoder) Failures transcoding multi-channel audio on Windows
Plex Media Server 1.15.1.791 is now available to everyone
Note: Auto-update will be disabled for a few days. In the meantime, you can grab the new version from our Downloads page.
Plex Media Server 1.15.2.793 is now available to Plex Pass users in the Beta update channel
FIXES:
  • (Analysis) Chapters for multi-part media was not correctly imported (#9554)
  • (DVR) Don’t schedule in progress airings if sub doesn’t allow partials. (#9688)
  • (DVR) Fix a long-standing but rare crash when starting a live tune (#7790)
  • (Dashboard) User counts in Top Played could be inaccurate (#9730)
  • (Transcoder) A few seconds of audio could be missing after seeking while Direct Streaming both audio and video (#9658)
  • (Transcoder) Seeking could be unreliable with some DASH clients (#9137)
Plex Media Server 1.15.2.793 is now available to everyone
Plex Media Server 1.15.3.835 is now available to Plex Pass users in the Beta update channel
NEW:
  • (Subtitles) Support txt uploads (#9398)
FIXES:
  • Cases where having “web-dl” in the filename prevented matching.
  • When manually selecting an audio stream in your language, subtitles in your language could be incorrectly selected.
  • When playing in the middle and returning to start, view offset is properly saved.
Plex Media Server 1.15.3.858 is now available to Plex Pass users in the Beta update channel
FIXES:
  • Analysis could fail to set media item attributes
Plex Media Server 1.15.3.858 is now available to everyone
Plex Media Server 1.15.4.919 is now available to Plex Pass users in the Beta update channel
NEW:
  • (DVR) Ability to give Home Users DVR access. (#8794)
  • (Playback) Assume unknown audio to be foreign if the preferred audio language is not english (#6126)
  • (Streaming Brain) Preference to allow automatically terminating playbacks which have been paused for an hour (#9700)
  • (Subtitles) Auto select forced subtitles when not listening to foreign audio (#6126)
  • When transcoding for supported clients, automatically select media based on supported resolution and dynamic range (#9490)
FIXES:
  • (Analysis) Chapters were not being imported for new media (#9843)
  • (Dashboard) Respect user preferences for local / remote bandwidth (#9562)
  • (Dashboard) Respect user preferences when showing streams as local / remote (#9562)
  • (Metadata) Asking to refresh metadata still used cache for movies and TV shows (#1566)
  • (Metadata) Related collections were not paginated (#9844)
Plex Media Server 1.15.4.993 is now available to Plex Pass users in the Beta update channel
NEW:
  • (Web) Updated to 3.95.2
Plex Media Server 1.15.4.993 is now available to everyone
Plex Media Server 1.15.5.994 is now available to Plex Pass users in the Beta update channel
FIXES:
  • (Analysis) A data structure was freed twice (#9865)
  • (DVR) Shows with a title ending in a special character would sometimes fail to record on Windows. (#9763)
  • (Music) Local artist music videos were unintentionally hidden for all users (#9923)
  • (Music) Local artist music videos would not have thumbnails
  • (Photos) Place tags could get duplicated (#9884)
  • (Transcoder) The server could crash if an HLS subtitle segment was requested while the session was terminating (#9927)
  • Transcoded sparse subtitle streams in HLS could take too long to respond (#9921)
Plex Media Server 1.15.4.994 hotfix is now available to everyone
NEW:
  • Allow all users with linked TIDAL accounts to access Add to Library features.
FIXES:
  • (NAS) No longer require ‘administrator’ permissions on Synology devices. More info here
