Server Version#: 1.19.4.2935
I keep matching them manually and they keep reverting. I’ve added logs.
Logs here: https://we.tl/t-VZj3MXquk8
FYI, you can attach log files directly to the thread. Just drag the zip file into the compose window.
You need to follow Plex naming and organization recommendations.
See Your Media -> TV Show Files (Naming and Organizing)
Season XX folder for each seasonShowName - sXXeYY.ext
After renaming/reorganizing, Plex Dance the entire show to clear the incorrect data from the Plex server database.
Many people use FileBot, https://www.filebot.net/, to assist with naming files. It has presets that conform to Plex recommendations.
From your log files:
/media/big/zzztorrents/series/Last.Week.Tonight.with.John.Oliver.S07E06.1080p.WEB.H264-XLF[rarbg]
/media/big/zzztorrents/series/Belgravia.S01E03.1080p.AMZN.WEBRip.DDP2.0.x264-QOQ[rarbg]
/media/big/zzztorrents/series/The.Good.Fight.S04E05.The.Gang.Goes.to.War.1080p.AMZN.WEBRip.DDP5.1.x264-NTb[rarbg]
/media/big/zzztorrents/series/Young.Sheldon.S03E20.1080p.WEB.H264-XLF/young.sheldon.s03e20.1080p.web.h264-xlf.mkv
/media/big/zzztorrents/series/Star Trek The Next Generation/Star Trek TNG Season 01
/media/big/zzztorrents/series/Star Trek The Next Generation/Star.Trek.TNG.S01.Bluray.1080p.DTSMA.7.1.V2.x264.dxva-FraMeSToR
Following Plex guidelines:
/series <-- TV Library points here
/Belgravia
/Season 01
/Belgravia - s01e03.ext
Before I commit to that kind of change (please note content delivery on my setup is pretty much automated), can you please point out what the issue is exactly?
Because it used to work perfectly until two or three server releases ago, including with the shows mentioned here. And now it doesn’t work anymore even when I manually match the show to the correct tvdb entry.
My library actually points to the “/series” folder and sonarr does actually break down series in correct folders via symlinks on the ext4 parititon.
If I may add here?
I use Sonarr. I avoid symlinks and let Sonarr deposit the files into their final location.
Hey ChuckPa, thanks.
What download client are you using for sonarr?
