Plex mediaserver on Raspberry Pi service not starting
Server Version#:/plexmediaserver_1.41.3.9314-a0bfb8370_armhf.deb
The service seems to install correctly but fails to start
from the journal
Dec 31 20:17:08 media1 systemd[1]: Starting Plex Media Server…
Dec 31 20:17:08 media1 systemd[1]: Started Plex Media Server.
Dec 31 20:17:08 media1 systemd[1]: plexmediaserver.service: Main process exited, code=killed, status=11/SEGV
Dec 31 20:17:08 media1 systemd[1]: plexmediaserver.service: Failed with result ‘signal’.
I have checked and plex user has access to the folders .
Any idea of where I look next for the problem
David
ARMhf (hardware float).
Does your machine have neon extensions?
Not sure - how do I check?
It is an old Rasperry Pi "cat /proc/cpuinfo " shows
processor : 0
model name : ARMv6-compatible processor rev 7 (v6l)
BogoMIPS : 697.95
Features : half thumb fastmult vfp edsp java tls
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xb76
CPU revision : 7
Hardware : BCM2835
Revision : 0010
Serial : 0000000044182b90
Model : Raspberry Pi Model B Plus Rev 1.2
