Plex memory leak?
Server Version#: 1.18.6.2368
So after the latest update, i’ve been logging into my NAS which ahs 4GB of ram and typically sits at about 36% with plex etc on and I’ve noticed once it was on 66% ram, and just now it was on 89% RAM usage. both times I disable plex and then re-enable. Effectively restartign the server and the RAM usage goes back down, this tiime it went from 89% down to 9% with plex disabled. With plex enabled again and streaming to my pc right now the RAM is back at 14% usage. This has only happened on my WD nas, post the latest update.
Still no response to this, i’m still getting the leak and it is definitely a memory leak and it is definitley plex causing it. It’s only happened with the lastest updates
I’m have a same problem.
hmm i could not see that message from RAM. DLNA server was indeed active, so I guess that might be it.
