Plex merging two folders together
I didn’t know where else to put this but the issue I am having is that Plex is taking 2 movies and combining them together in the library layout. The movies in question are:
1. I Am Legend (2007)
2. Legend (1985)
I have these in 2 separate folders and named as above. No matter what I do, I can’t get them to not be combined. I have also gone through the metadata of each file to make sure nothing is crossed over and there is nothing there. I have had this issue in the past and I was able to fix it by removing one file from the movie directory on my server and then putting it back in, but for some reason, I can’t with this one.
i am legend
What version of Plex Media Server?
If v1.20 or higher, which agent are you using, Plex Movie or Plex Movie (Legacy)?
Instead of just moving the files in/out of the library, do a full Plex Dance for both movies.
Add them back one at a time.
If Plex still combines them, then split them apart and perform a Fix Match on the one that is mis-identified.
Click on the three vertical dots in lower right corner of cover art to pull up the menu:
Screenshot (402)
If you are using the new Plex Movie agent, you can add the IMDB/TMDB ID to the folder & file name. Plex will use it for matching.
See Naming & Organizing Your Movie Files for info on how to add the ID. Ex: Batman Begins (2005) {imdb-tt0372784}.mp4
To change from the legacy to new movie agent, see Scanners & Agents -> Upgrading a Movie library to the use the new Plex Movie Agent.
Include the year into the folder name as well.
Try a simple “Split”, followed by “Fix Match” on one of them.
