Plex Mix Error - Gracenote possible culprit
Ever since migrating server from old hardware build (Windows server 2016) to new hardware build (Windows server 2019 preview), Plex Mix has refused to work. This was in June.
I have performed multiple DB repairs, as described in this guide to no avail. Deleting and recreating the Library also does not fix the issue.
As a workaround, creating a secondary VM (Running Windows 10) with a new plex install and new library works. I’d prefer to fix the main install however. Creating an entire new install and losing TV/Movie watched status is not an attractive option.
I’ve done a fair amount of troubleshooting into this issue, and I believe I have narrowed it down to some weirdness in the database regarding the ‘gn_genre’ attribute. It almost looks like a locale setting is missing for my server.
Going through the logs, when the server fails to create a plex mix playlist, I get the following:
Sep 26, 2018 17:01:31.878 [10084] DEBUG - Request: [192.168.1.1:51566 (Subnet)] POST /playQueues?type=audio&shuffle=0&continuous=0&uri=library%3A%2F%2F275f36e5-7b08-40d9-8ee1-b5baa5c9363b%2Fdirectory%2F%252Fservices%252Fgracenote%252FsimilarPlaylist%253Fid%253D269111&includeRelated=1 (12 live) TLS GZIP Signed-in Token (username)
Sep 26, 2018 17:01:31.894 [10084] WARN - LPE: falling back to slow path evaluation: /services/gracenote/similarPlaylist?id=269111
Sep 26, 2018 17:01:31.894 [10084] DEBUG - Downloading document http://127.0.0.1:32400/services/gracenote/similarPlaylist?id=269111
Sep 26, 2018 17:01:31.956 [10084] ERROR - Gracenote: Exception error -1870069037 (no locale loaded to support 'like' operator for attribute 'gn_genre')
Sep 26, 2018 17:01:31.956 [10084] ERROR - PlexClient::downloadContainer: expected MediaContainer element, found html
Sep 26, 2018 17:01:31.956 [10084] ERROR - LPE: failed to get container for path: /services/gracenote/similarPlaylist?id=269111
Sep 26, 2018 17:01:31.956 [10084] DEBUG - PlayQueue: Start index: 0 End index: -1 Count: 0
Sep 26, 2018 17:01:31.956 [10084] DEBUG - PlayQueue: 0 generated IDs compressed down to a 2 byte blob.
On the VM where Plex Mix works, this is the log detail
Sep 26, 2018 14:39:57.772 [6204] DEBUG - Request: [192.168.1.1:52186 (Subnet)] POST /playQueues?type=audio&uri=library%3A%2F%2F%2Fdirectory%2F%252Fservices%252Fgracenote%252FsimilarPlaylist%253Fid%253D11087&key=%2Flibrary%2Fmetadata%2F11087&repeat=0&own=1&includeChapters=1&includeGeolocation=1 (23 live) TLS GZIP Signed-in Token (username)
Sep 26, 2018 14:39:57.772 [6204] DEBUG - PlayQueue: 0 generated IDs compressed down to a 2 byte blob.
Sep 26, 2018 14:39:57.788 [6204] WARN - LPE: falling back to slow path evaluation: /services/gracenote/similarPlaylist?id=11087
Sep 26, 2018 14:39:57.788 [6204] DEBUG - Downloading document http://127.0.0.1:32400/services/gracenote/similarPlaylist?id=11087
Sep 26, 2018 14:39:58.022 [6204] DEBUG - GN: Generated playlist with 61 items
Sep 26, 2018 14:39:58.100 [6204] DEBUG - PlayQueue: Start index: 0 End index: 61 Count: 62
Sep 26, 2018 14:39:58.100 [6204] DEBUG - PlayQueue: 62 generated IDs compressed down to a 215 byte blob.
Sep 26, 2018 14:39:58.132 [6204] DEBUG - PlayQueue: Added 62 items in 0.0 sec.
What I’m stuck at now is how I can possibly manually fix my database or set that locale setting (If this is truly the issue). Any help is greatly appreciated!
