Plex Movie Agent missing from settings
Server Version#: 1.25.1.5286
Player Version#: na
When I go to Settings…Agents…Movies I see the following:
Personal Media Plex Movie (Legacy) The Movie Database
I do not see Plex Movie without Legacy next to it.
However, if go to my library and Manage Library…Edit…Advanced… in the Agent drop down it lists 4 options. Personal Media, Plex Movie (Legacy), Plex Movie, and The Movie Database. And Plex Movie is selected.
I wanted to check the settings on the Plex Movie agent to make sure it’s grabbing collection tags but since I can’t see it in settings, I’m not sure what to do.
Thanks,
Roger
Only the legacy agents use server wide settings. The current generation (e.g. Plex Movie, Plex TV Series, Plex Music) can be configured per library. Therefore those aren’t represented in Settings > [Server Name] > Agents.
To configure the current agents, you need to “edit” their respective libraries (via ⋮ > Manage Library > Edit... → Advanced from the library’s context menu)
thank you. that explains it
