Where are Plex Movie agent settings?
I migrated my movie libraries to use the new “Plex Movie” agent, but where are its settings? In Settings > Agents I see this:
Why is “Plex Movie (Legacy)” still there if nothing is using it and “Plex Movie” is missing? Any way to fix this?
The modern agents are configured per library… mostly using the advanced tab of each particular library. There’s no centralized server-wide agent configuration for those.
They were moved into the Library Advanced tab. The settings below the Agent dropdown change according to the selected agent.
If you have more than one Movie library, this allows you to have different settings in each library while using the same agent.
Makes sense, I was just confused by the screenshot on the page below, but I’m guessing it’s from before the agent was renamed to “Plex Movie (Legacy)”.
:wink:
