The whole “Agents” settings section only deals with legacy agents.
You can disregard everything under “Agents” if none of your libraries is using a legacy agent.
The properties of the new agents are all customizable in the properties of each library.
Which means that you now can have different agent settings for each library, which was not possible with the old agents.
