I am using the new Plex Movie Scanner, and Agent. I have refreshed my entire library.
After this, I’ve noticed some issues under the guid metadata.
The Courier (The Courier (2020) — The Movie Database (TMDB)) missing a TMDB ID. Fix Match showed two results:
After refreshing using the result with the cleaner poster, the GUID data seems accurate/good:
imdb://tt8368512
tmdb://522241
tvdb://65088
Suggestion: Remove the result/record that has the poster with more text on it? (the one missing a TMDB id).
Good Boys (Good Boys (2019) — The Movie Database (TMDB)) missing a TMDB ID. Fix Match showed two results:
After refreshing using the result with the cleaner poster, the GUID data shows multiple IMDB IDs:
imdb://tt6977338
imdb://tt7343762 - this just redirects to the first
tmdb://521777
tvdb://22441
Test redirect by IMDB here: Good Boys (2019) - IMDb
Suggestion: Remove the result/record with the poster with more text on it (the one missing TMDB id). Fix the other result by removing the imdb record of tt7343762.
Tesla (Tesla (2020) — The Movie Database (TMDB)) showing multiple IMDB IDs. Fix match shows two results:
Fix match using result where the poster has no text at the top:
imdb://tt5259822
imdb://tt2772304 - this is completely wrong
tmdb://517412
Test wrong result: Tesla - IMDb
Fix match using the other result doesn’t have a TMDB:
imdb://tt5259822
tvdb://138499
Suggestion: From the cleaner poster result, remove the IMDB record for tt2772304. Remove the other result?.
The Great Hack (The Great Hack (2019) — The Movie Database (TMDB)) showing multiple IMDB IDs. Fix match shows two results:
Mine is matched to the bottom result (with more description info / cleaner poster):
imdb://tt4736550
imdb://tt9358204 - this just redirects to the first
tmdb://566222
tvdb://87421
Suggestion: From the cleaner poster result, remove the IMDB record for tt9358204. Remove the other result?.
Hopefully this can be tidied up.
Thanks!
