I have a very strange music scanning problem. Using latest Plex Server, using default Music library settings. The music scanning time is super unusually long.
For example, please test this sample file:
The zip has 2 albums in MP3 format.
With Plex Server on both QNAP and Windows, scanning this 2 albums folder, takes at least 30mins to over 1 hour!
This can’t be right, right? I hope someone can tell me what’s wrong with my music files, or it’s Plex server setting issue (using default settings now).
Thanks!
Server Version#: 1.32.3.7162
Remove the embedded cover from all files, then test again. Leave only the external cover.jpg
To speed up scanning, embed an AlbumArtist meta tag.
The single-disc album contains 2 instances of the Album Title meta tag.
I was able to pin it down to the Brandenburg Concertos album.
What ever I did, the scanner would hang on this one.
I even completely rewrote the mp3 file structure using a very thorough mp3 repair tool.
I will forward this one to the developers.
Thanks for checking my question!
I use MP3Tag to remove all embedded artwork, and added AlbumArtist on the 2 albums. Then scan the folder again in Plex. It still takes around 30mins to scan. It makes no difference!
On the same Windows PC, MusicBee only took a few seconds to scan the 2 albums!
