Plex Mutliple ATV's
I am currently using one ATV3 and one Roku but the Roku interface is really ugly (I use the iOS plex app on my phone and iPad so I don't have to look at it) so I'm looking to get another ATV3. Is it possible to run two ATV3's on the same network to access plex?
Yep! I bought another ATV for PlexConnect too and it's officialy supported and works like a charm.
Just don't forget installing the profile for Http ;)
Since I've already installed it on one ATV do I have to remove it off the first device and then install the same certs on both?
I use the same cert on all my mac's and atv's
I don't have the old cert folder so I would imagine I'd just to have to start the process again? Wouldn't take long either way.
Check your program you originally used to install the cert. Maybe its there?
No no, just install same cert .. If it's deleted create a new one and install on the new ATV
OK so the old ATV will still work and the trailers.pem file will be the same on the new ATV with the new certs created?
Ye, don't touch old ATV, just install cert to the new one and enjoy ..
Excellent, thanks!!
...with new Cert on new aTV as well as in PlexConnect, your old aTV wouldn't accept the https stuff provided to it, right?
My guess: A new Cert in PlexConnect will force you to update the Cert on your old aTV as well. I might be wrong here... but that is how I understand it.
Ignore
Plexify? This is not about the OS X app, is it?
akeezer "lost" his original Cert. I just wanted to point out, that the given advice is not completely correct... assuming he wants to still use his original aTV with Plex/PlexConnect as well.
Mixed up threads, my bad
AppleTV is listed under Devices but when I click install it doesn't change to remove. Any ideas?
...Underlying error:
NSError:
Desc   : The required field PayloadIdentifier is missing.
US Desc: The required field PayloadIdentifier is missing.
Domain : MCProfileErrorDomain
Code   : 1002
Type   : MCFatalError
Params : (
PayloadIdentifier
Nov 13 17:56:33 Apple-TV identityservicesd[44] : [Warning] Device is not setup, trying to re-certify in 15.000000 seconds
Nov 13 17:56:35 Apple-TV addaily[113] : addaily ended
Nov 13 17:56:39 Apple-TV mc_mobile_tunnel[114] : (Note ) MC: mc_mobile_tunnel shutting down.
Nov 13 17:56:40 Apple-TV profiled[115] : (Note ) profiled: Service stopping.
The cert is installed and if I try to remove it to create a new one it won't let me.
Just as an update to this as my original cert didnt work.
SOLUTION:
Delete the cert directory (C:/Cert) and contents of c:/PlexConnect/assets/certificates except for certificate.txt)
Downoaded txt.gif  cert.create.txt   364bytes
Copy to C:/Cert
Renamed to cert.create.bat
Right click and run as admin
Copy the three files created to c:/PlexConnect/assets/certificates
Create a copy of trailers.der and rename to trailers.cer
Run plexconnect.py
On the Apple TV choose Setings-> General -> Network and change DNS to the DNS of your PC/Plex Server
Then General -> Send Data To Apple and click the Play button and Add Profile
Enter http://IP of your Plex server/trailers.cer" - IP of your plex server is your DNS
This will install your cert in your c:/PlexConnect/assets/certificates and you can do this on multiple devices.
