Plex naming of TV shows
I’m having a serious problem with plex incorrectly naming tv shows. No matter what name I give the show it changes the name to Aqua Team Hunger Force. Never ever watched that show and never even heard of that show.
Here is the correct name: Battlestar Galactica 1978 SXXEPXX.
Anyway to fix this plex error.
BTW, Movies it names okay, it just isn’t working for TV shows.
David
Naming is not SxxEPxx but SxxExx
https://support.plex.tv/articles/200220687-naming-series-season-based-tv-shows/
My files on my sever are named correctly. See image)
When i scan the folder the episodes are named episode 1, episode 2, etc instead of the correct tile and description.
Suggestions?
Try adding the Series title, e.g.
The X-Files - s01e01 - Pilot.avi
At least that’s how I have named mine
Go into your tv show library properties. https://support.plex.tv/hc/en-us/articles/200289266-Editing-Libraries
Which path is set under the ‘Add Folders’ tab?
If it is only Multimedia/TV Shows, then this won’t work.
You must add in there each of your ‘index letter’ sunfolders individually
e.g. Multimedia/TV Shows/R - Z
It helps to add the release year of s01e01 in parentheses to the show folder name, in this case Multimedia/TV Shows/R - Z/The X-Files (1993)
Afterwards, perform the Plex Dance to clear out any mismatches from the Plex database.
