Plex NAS Server extreme memory use
Server Version#: 1.23.2.4656
Player Version#: N/A
Since a couple of days I have Plex server taking up 1GB more of RAM on my x86 Qnap NAS with 2GB RAM. none of the qnap processes take more than a ~ 80 MB of RAM. I downloaded the logs from the server but so far did not find the culprit, any idea where (what log file,…) to look?
Be careful what you look at.
There are two values. One is important, the other is.
  1. Virtual Size = How much the program allocated to itself (may not be in use)
  2. Resident Size = How much physical memory is actually in use.
QNAP Resource Monitor shows Resident Size.
This server has been running for over 2 weeks and is part of my daily testing.
It’s “Virtual size” is 1.2 GB. As you can see, it’s Resident Size is about 200 MB.
I also have a TS-128A , with 1GB memory. PMS runs just fine in it other than being a single-disk ARMv8 development system)
Thanks for your reply! Looking in my Resource monitor, I see 1.17 GB resident size. I suspect it has something to do with Plex’s internal scheduled tasks; directly after NAS reboot I am at around 160 MB resident size but the next day the NAS becomes unresponsive, the HDDs are working 100% and Plex’s resident memory climbs to 1GB+. This has started a couple of days back, prior to that I never had an issue.
If PMS is generating Chapter Thumbnails then it’s resident size will grow for the duration.
It explains why the HDDs are so busy.
There was a bug in the previous versions which I found and Engineering was just now able to fix in this release.
the bug was:
  1. Create a library section
  2. Analysis starts
  3. Thumbnails start
  4. If anything interupted this, PMS would never restart & complete the task.
Now, PMS will catch up all that work.
I will need your DEBUG log files ZIP to confirm what’s happening.
I have uploaded the logs I captured AFTER I rebooted the NAS. Prior to reboot it was impossible to gather them.
Thank you!
going through the logs I noticed a name of one the series come up way too often - after deleting the folder, the problem disappears. I don’t know where exactly is the problem (corrupt file? unsupported file?) but the memory load is gone.
