Plex never works
Plex only works maybe once every ten times I try to use it. And that usually involves uninstalling the server program and starting all over every time. What a piece of ■■■■! Is anyone else having the same issue?
If you want help then post details!
What machine your server is running on.
What else is running on the server.
What client you are using.
How the server and the client are connected to your network.
What media you are trying to play.
And post logs if at all possible.
https://support.plex.tv/hc/en-us/articles/200250417-Plex-Media-Server-Log-Files
On the other hand if you just want to complain the go ahead and complain. But do not expect much sympathy as Plex works quite well for most and even though I am, probably, moving to Emby it has nothing to do with Plex’s server or reliability. Plex is a stable, reliable piece of software in most every reasonable setup.
