Server issues
Hi Im having issues with my Plex as it works one day then doesnt work the next. It tells me
DESKTOP-PLEX is currently unavailable
Verify you have a network connection and that the server is online, or see our troubleshooting tips for further assistance.
I remove the server from windows and install again and normally this works but maybe 90% of the time. Once I get it working again as soon as I turn off my computer the next day it comes back with the same issue. Ive been removing and re installing it daily to Keep the server connected. Is this normal and how do i fix this it SUCKS.
Just to be sure, are you certain you have Plex Media Server configured to start automatically at login:
And even with that setting enabled, unless you’ve configured PMS to run as a service, it won’t start until you’ve logged on to your computer.
Aside from that, logs showing the issue could be helpful (pay particular attention to point 3):
