Server Version#: 4.12.3
Player Version#: 7.27.0.15018
I used to be able to repeat a playlist endlessly - now if I click on Repeat and then select “Repeat all” it just goes back to “Repeat None.” We were using this as a kiosk to play videos of our adoptable animals at a shelter. No one has been able to figure out how to get a playlist of videos to repeat again.
I’m having the same problem. I’m able to repeat the playlist when viewing using a web browser, but unable to do so on the Firestick. I’d like to add that I’m unable to “Repeat One” and “Repeat All”.
Same issue here. Plex on fire stick version 7.30.2.16712
Same issue w/ the plex web app on mac/windows/chrome
server version is 1.19.1.2645
I’ve always had issues w/ repeat/repeat 1 and shuffle. plays one item and quits. doesn’t matter if its a music playlist or video list.
Same here - looking for any update.
I desperately need this function back on both fire stick and shield. I use those devices to run a video playlist continuously in ny store
I was thinking a solution would be to continue to re-add those same files as many times as needed, but it looks like plex doesn’t allow you to do this either.
I feel like I use to be able to do this. I am almost positive I did this before.
Maybe you could make multiple copies of those files and let plex recognize it as multiple/duplicates… then split apart if necessary and then add them into a playlist. If that makes sense…
