Plex no longer functioning - WDMyCloud
I have had Plex server on my WD MyCloud device for many years, no issues, till today.
I went to my Plex and none of my items were showing, custom directories, etc.
So, I rebooted MyCloud, no luck, went to configure Plex, all it came up is with a blank page.
I went and uninstalled Plex, rebooted MyCloud, reinstalled, rebooted and tried again. No luck at all.
I checked the custom directory structure and everything is still there, so, something happened. I even downloaded the plex for my unit and did the update, still does not work.
Any suggestions or recommendations on what to try to get it to work again?
Is it a Plex update or a WDMycloud update that caused it?
Thank you
Rob
In case this is needed:
|App Name:||Plex Media Server|
|Version:||1.40.4.8679|
|Installed on:||Tuesday, 2025 June 10, 1:58:13 PM|
WD MyCloud firmware info
|Current Version|5.31.102|
|Last Update|Friday, 2025 June 06, 3:58:56 AM|
Where are the logs found on the device?
Ok, found system logs, don’t see anything but 2 warnings
2025 Jun 10 13:51:00 OTHER [ 60.871013] restart sysinfod…
2025 Jun 10 13:28:51 OTHER [ 75.121797] restart sysinfod…
2025 Jun 11 04:28:29 SAMBA CIFS: [ipv4:192.168.1.134:50318] connected to [Movies_Music] as user [admin].
2025 Jun 11 02:30:05 RTC Set System Time.
2025 Jun 11 02:30:00 OTHER 2025-06-11 02:30:00.549542 (+0800) -0.055104 +/- 0.065671 time.windows.com 168.61.215.74 s3 no-leap
2025 Jun 11 02:30:00 OTHER sntp 4.2.8p15@1.3728-o Mon Jan 16 16:49:32 UTC 2023 (1)
2025 Jun 11 02:29:22 RTC Set System Time.
2025 Jun 11 02:30:01 OTHER 2025-06-11 02:30:01.074500 (+0800) -43.463060 +/- 29.003806 time.windows.com 168.61.215.74 s3 no-leap
2025 Jun 11 02:30:01 OTHER sntp 4.2.8p15@1.3728-o Mon Jan 16 16:49:32 UTC 2023 (1)
2025 Jun 11 00:00:00 OTHER Set check central server at 1:39
2025 Jun 10 20:04:13 SAMBA CIFS: [ipv4:192.168.1.134:57573] connected to [Movies_Music] as user [admin].
2025 Jun 10 13:59:26 SAMBA CIFS: [ipv4:192.168.1.240:65213] connected to [Movies_Music] as user [admin].
2025 Jun 10 13:51:28 SYSTEM System is rebooted or power up successfully.
2025 Jun 10 13:51:28 OTHER Set check central server at 10:6
2025 Jun 10 13:50:52 RTC Set System Time.
2025 Jun 10 13:50:47 OTHER 2025-06-10 13:50:47.141429 (+0800) +0.913235 +/- 0.639956 time.windows.com 40.119.6.228 s3 no-leap
2025 Jun 10 13:50:47 OTHER sntp 4.2.8p15@1.3728-o Mon Jan 16 16:49:32 UTC 2023 (1)
2025 Jun 10 13:50:47 SYSTEM Firmware Version : 5.31.102
2025 Jun 10 13:50:47 RTC System Time Is Updated By RTC.
2025 Jun 10 13:49:00 SYSTEM System rebooting.
So I was having trouble myself with my WD PR4100 and after the latest update my Plex server would not load.
So I tried uninstalling/ reinstalling and was considering giving up until I just went back into the MyCloud software - went to Plex Media Server in installed apps and the Run App toggle was switch to off!!
Toggle it back on an hey presto.. back online! Worth a check!
