Please let me know if the new NVIDIA_GPU_DRV timing works?
https://support.plex.tv/articles/115002178853-using-hardware-accelerated-streaming/
i donāt have an nvidia graphics card in the nas. assuming i would need that to test the NVIDIA_GPU_DRV timing?
sorry to rain on the parade, but even with fresh v1.40.5.8921 PMS still wonāt launch after a powercut to the QNAP NAS. it starts fine after a normal reboot. after a powercut there is no sign of the system trying to launch PMS inside āPlexMedia Server.logā and running āplex.sh startā manually works fine, resulting in:
Plex Media Server is recovering from previous crash. Please standby.
Starting Plex Media Serverā¦
i am giving up, will just upgrade the UPS.
Is this fixed in 1.41.2.9200?
Iām on 1.41.3, and this is still an issue for meā¦
My QNAP is firmware version 5.2.2.2950, if that is affecting anything.
I am on 1.41.3.9314 and I am still getting the issue where plex does not start after my QNAP nas shutsdown uncleanly.
Is anyone else still having the issue?
yes, it is not fixed.
Repair or restore the databases from a previous backup.
After an abrupt / unclean shutdown, the DB will need repair.
If not already enabled, temporarily enable the admin user to run this:
After an āautoā repair sequence, if it still doesnāt autostart , Please grab and attach a ZIP file of the Logs directory under Plex Media Server
From that, weāll know if you need to roll the DB back to one of the backups (which the tool will also do for you)
if a corrupt DB was the issue, why would manually launching it work just fine?
Yeah thatās what I thought.
Iāve been having this problem for years.
My Plex server was recently updated - same issue when my power goes out.
I have not tried doing the manual method.
The people replying in this thread talking about a corrupt database are just confused.
if the NAS/Qnap is shutdown uncleanly, Plex will always need a manual startup (or restart) - no problems starting it manually.
according to other responses, this is due to a glitch? Itās been like this for years even on mulitple Qnap devices.
Hello,
after upgrading to latest PMS v.1.41.5.9522-a96edc606, every time I reboot my QNAP (correctly because reboot is scheduled every night) with firmware version 5.2.4 build 20250321, Plex not automatically start. To solve I need to logging into the NAS as an Admin and restarting the app.
I didnāt have this problem with the previous release, and my db is fully ok, I made a repair with your ChuckPA repair tool.
Please help me or tell me how to open a ticket to official support (I have a full Plex Media Pass lifetime).
Thank you.
Do you have a PlexData shared folder ?
If you donāt,
- Create the shared folder, named exactly
PlexData. - Restart PMS
- Let it run 60 seconds
- Download the logs ZIP file
Next time it does not start, use PlexData in FileStation
PlexData ā Plex Media Server ā Right-click āLogsā ā Compress (zip file)
Download the ZIP and attach here.
QTS should be restarting PMS by itself.
You might need to reinstall (on top of ā donāt uninstall the existing) to get QTS to update itself.
Hello,
thank you very much for your reply.
I alredy have a Logs folder in this path:
/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Library/Plex Media Server/Logs
Is that enough or do I have to create anyway the shared folder PlexData?
Best regards.
If you can make a tar.gz of the Logs drectory and attach it here, great!
I was offering the PlexData shared folder so you had a GUI access method
Hello,
I apologize for the delay in my reply, but after reading your Qnap FAQ, I found a lot of bad configurations in my installation. So I made the decision to reinstall all from scratch.
I completely removed the package and the directory:
then I made a new fresh installation from latest stable release and I solved all my problem.
Now my QNAP correctly start Plex at every scheduled reboot.
Thank you very much for the support.
Best regards.
GreatGonzo
Not a coder by any means so Iām trying to decipher everything being discussed here.
Has this problem been resolved and if so, I need a grade 5 level way to fix it because itās a huge pain when Iām getting power flips hereā¦always happens to be when Iām away from home.
no
Do you have a UPS connected to the NAS ?
That will prevent sudden reboots / failures from short power interruptions / fluctuations.
Itāll also prevent things from getting corrupted by the interruptions (no interruptions at all). The UPS will tell the host when battery is low so the host can do an orderly shutdown.
No I donāt have a UPS set up, but going to do it soon.
I guess there really is no fix then huh?
