Haha, ok! Thanks for all your help anyway
I’ve tried adding or deleting years, and unmatching and rematching, so for now, I’ll just sit tight. It doesn’t bug me too much except for the fact that it should work, and I’m definitely not going to go through hand editing! Thanks anyway though!
@MillerMedia said:
Ok, I missed the (2008) thing, whoops. But I’ve got that fixed now, and I went through the process again, still no luck. Here’s some more screenshots, but I’m fairly certain I didn’t miss anything this time. NewPlaza, I also included the screenshot you requested. As another attempt to remedy the problem, I deleted my TV Show library and re-created it, this time using The Movie Database as the agent, which seems to have fixed my problem with Doctor Who, but the problem is still continuing with bot Merlin and The Flash.
Am I reading it correctly that you have the TV folder inside the Movie folder?
They should be seperate folders for each. Not sure if that could be the problem; but it sure isn’t helping.
If that’s the case - you’re right - bad juju there.
