Server Version#: 1.18.9.2578-513b381af
Tuner Make/Model: Hauppauge hvr-2250
Guide/Lineup name:
Using XMLTV?:
Channel number/Name:
Running Ubuntu 18.04. Drivers installed and tuner works in Kaffeine
No Linux Support? Should I try running server under windows?
The WinTV HVR-2250 is supported by PLEX, on Windows 10 at least. If you use the WinTV-quadHD driver on Windows 10, the tuner should show up just fine. I’ve ported my install across 3 hardware platforms without issue. The driver installer scans the bus & installs drivers for all Hauppauge cards in one process.
Thank You. I have it running now under windows.
