Plex Not Finding Metadata
Hello, I´m JeiBee
My computer skills are low and I have the same problem, besides my english for these subject that is so weak
My Plex was downloading metadata normally but suddenly it stopped
I read some other people in the forum and I tryed to use my mobile as modem. It worked well
The metadata are downloaded normally but it waste all my mobile internet that´s expensive in Brazil. Bersides that, I want to really fix the problem.
Could you give me a basic step by step to try to do what you did?
Thank, best regars
Jeibee
My problem is that plex never stops, it’s seems to be scanning my lybraries on and on
Please ignore my last message
Let’s concentrate on the downloading metadata issue
The last message is just about my momentary difficult to sending You the log file you asked for
Sorry
I received the Your answer here and i kept answering here
Where in Plex Fórum I have to enter, please
Thanks you for your help
I’m trying to access Plex Forum to enter this message but i don’t know what’s happening.
After a long activity here with my network provider, i convinced him to disable IPv6 in my Pc network adapter, once my mobile provides only ipv4
It was successful and i would like to share this with other people in the forum
People in the forum helped me a lot once, If i haven’t read It in the fórum, i would never know that there os something called IPv6
I just think Plex might have a “Test Your connection” button or step by step instructions in the troubleshoting section
It would save a lot of work for people people like me
Best regards
Jacques
Trumpy81, I was trying to thank you.
Sorry if I communicated by email, I was receiving your messages by email in my mobile and answering the same way, once I was not logged in. I was very anxious to fix the problem.
The problem is fixed now as I said before. We disconnected IPV6 in the PC network adapter.
I use here a dual band modem with wifi without router appart. So I received they´re personnal support and I was looking for closed doors or a IPV6 problem as I read in the forum
I think my Plex log is no longer usefull and I’m not close to my server now.
I’ll send you latter
Best regards
