i have the same issue but it is on unraid but my movie file is the only one that works. tv and music just stooped randomly
please don’t hijack other threads… that’s just creating confusion on all ends.
-> moved your post to a new thread.
Would you mind sharing some more details…
- have you checked Plex can see the files (permissions etc.)?
- is it not recognizing some of the files or all of them? (e.g. can you still play files already scanned/matched?)
- what server version do you have installed?
- example of your file naming / folder structure
sorry
everything was able to be seen at one point in time but it just stoped recognizing it. tv it wont recognize the file when i scan it but music it recognizes the music but it dos not let me play it .
we are on version 1.18.3.2156
The Mandalorian - S01E01
I just updated to 1.18.3.2156 and am having the same issue. I added a few tv shows and the ones that were already scanned and in the database showed up but a new tv show folder isn’t showing up. I have scanned the folder a few times. I also notice that now my remote access is going in and out randomly since updating.
ok so it is probably the update
is there a way to revert back so it fixes the issue?
Maybe, maybe not. I’ve got Version 1.18.3.2156 running and no issues with new TV shows.
Since it’s anew TV show folder are you sure it’s not a permission issue with the folder?
i can try setting up a new tv folder and see if it works
that did not work
it flashes the library when it syncs and then just says it is There was an unexpected error loading this library.
i dont know what to do to get tv shows working again
Have you checked for a corrupt Plex database?
will this work with unraid
i can see them fine in the file but i cant see tv shows on plex it just says you have a issue go to forms
does this corruption sheet work with unraid or do you have to do it on the shared file side?
It works on the Plex Media Server, wherever it is installed.
