Plex not finding one episode of a show
Server Version#: 1.19.1.2645
Player Version#: Any
Windows 10 Pro
Missing episode
How my file is named:
RiffTrax - S03E117 - Courtesy A Good Eggsample
All other 342 episodes show up fine
File and folder permissions are fine, same as other episodes.
I copied and renamed one episode with the missing episode, still doesn’t find it. Made a new directory directly on the server with that episode, added it to TV library, still doesn’t find it.
I have done the PleX Dance with no success.
What else can I try?
How large is the file? Plex will ignore any files which are less than 300 MB in size and have “sample” in the file name:
So, try removing “sample” from the file name to see if that helps.
Good catch! It is below 300MB so I renamed it to:
And it showed up. Thanks!
No problem, glad it worked.
