Plex not making any changes after correctly matching music albums
Server Version#: 1.22.3.4523
So initially I thought Plex was just having an issue automatically matching my albums. However after manually identifying the correct albums using fix match, for some reason none of the metadata updates and the album is listed as “matched” when it is still using only the local metadata prior to putting it on Plex. Besides the naming of the files, does anyone have any ideas as to what the issue might be?
Disable “Prefer local metadata” in the properties of the library.
