Server Version#: Version 1.20.3.3437 (Synology DS218play)
Player Version#: Version 4.34.4 (Win 10 x64)
I try to Match an Album with a Match entry, when I click the desired option there is no effect on the album. Checking into the logs found a PUT Bad Request 400 when tries to apply the match.
I was waiting some problematic albums to fix and close the edit on MusicBrainz.
But I still have some problems with some albums, got error 400 when try to match.
I also found that after the 400 Error there is a XML error on the browser console:
XML Parsing Error: no root element found
Location: https://192-168-1-140.a131a13cf46c422488077f0f1e10400c.plex.direct:32400/player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1&X-Plex-Product=Plex%20Web&X-Plex-Version=4.46.2&X-Plex-Client-Identifier=yp0x11jzde8c54cef7x0xgwn&X-Plex-Platform=Firefox&X-Plex-Platform-Version=82.0&X-Plex-Sync-Version=2&X-Plex-Features=external-media%2Cindirect-media&X-Plex-Model=hosted&X-Plex-Device=Windows&X-Plex-Device-Name=Firefox&X-Plex-Device-Screen-Resolution=2560x740%2C2560x1440&X-Plex-Token=EPp_N_RDfz1RWzGMbKTS&X-Plex-Language=en
Line Number 1, Column 1:
There’s definitely a bug of some sort. I reported it here:
It’s easy to reproduce. Add an album that can’t be matched at MusicBrainz. Then add the album to the Musicbrainz database. Wait a few days for Plex to sync the data from their database… Match or Fix Match will bring up the proper album, but refuses to match.
A workaround till the bug is fixed is to “Refresh Metadata” for the artist. For some reason that will match the album properly.
Sorry for mixing something I didn’t put the whole context.
I’m new to Plex and MusicBrainz and I’m creating libraries for all my music, mainly electronic music form 1995 - 2015 aprox. For missing entries I try create new releases on MusicBrainz then I correct the names with MusicBraniz Picard application and I try to match in the Plex.
Said that, I had some problems matching albums that I created the entry on MusicBrainz.
When an album cannot match I see an HTTP error 400 always but unfortunately do not come with some information about what happens, so I’m try figuring out what is happening.
For now I spoted, problems when:
The album is with an open edting on MusicBraniz (show with the orange label), that was the case with Blanco & Negro album.
The album has multiple artists labeled in the Release. In this cases I’m trying to create a new artists entry in MusicBrainz as a Group to avoid the sync problems.
The album has multiple artitsts labeled in the Release Group.
In some cases I detected Plex duplicates the Artists entry and looks it breaks the system.
